pma4x4
AKA Yankeeroad
Ok, so we just got a 1991 Suburban 1500. I have already searched the forum and found some close answers but nothing definitive. I thought I would post this up as a whole and see what i find.
We are building the Suburban for expedition off-roading. This means it will see a lot of asphalt so ride quality is a priority. This will not be crawling rocks or doing WOT thru the mud. It will how ever be carrying a load. Below are the specs and the recipe of our lift. I am open to all opinions.
Specs:
1991 burby
5.7 TBI new GM motor 45k ago
700R4 with 30k GVW cooler
10 bolts front and rear geared to 4.10 Limited in rear. Rear will be trussed
33x10.50x15 BFG ATs Load range C
DYI4x Abomb winch bumper center WITHOUT the B52 mounts
Warn M8000 (yes I could use bigger but i had this laying around)
Recipe
Frontend
4" TC HD springs (stock length)
New ubolts
Bilstein 5125 valving 255/70 (there are other valving options I can go 298/94)
ORD shackle kit
All bushing greasable
FUSH kit from ORD
Rearend
Shackle flip kit from ORD or DYI4x (have not made mind up yet)
4.5 shackle from ORD or DYI4x (have not made mind up yet)
Ubolt reversal kit from ORD
Bilstein 5125 valving 255/70 (there are other valving options I can go 175/60)
STEERING
frame brace from ORD
Weld in frame plates from ORD
4" drop pitman arm (I do plan to swap out to crossover down the road)
I plan to add a bit more bumper material to the front but only in 1/8" wall type stuff.
The questions is am I going too heavy on the front springs? should i go with the EZ rides or stay HD. What do you think on the shock valving?
Specs:
1991 burby
Recipe
Frontend
New ubolts
ORD shackle kit
FUSH kit from ORD
Rearend
STEERING
The 5100s can be purchased application specific, but I just looked up their list of shocks and bought the ones that were the length I wanted.
