xpndbl3
Looking for real world experience from people who have used a 4" EZ ride tuff country or the HD springs, on a suburban with a zero rate and how does it ride? My 6" pro comp springs are too stiff, then I did a 5.3L swap and pulled 130-145 pounds out of the nose of the truck in the swap, so I removed 2 leaves out of the spring pack, it's still too tall and too stiff. So looking to swap to something that is more tolerable in pothole filled chicago streets.
, but that may be a different case with your suburban since you probably have more wight in the rear. Word of caution; if you load up the front end with a heavy bumper and winch the EZs will start to sag.
