410s are here -here goes the cash
only 31s
mass
they need new brakes all around,now im going from 6 lug to 8-ill put the rear on first-Not use the 4 wheel until front is in--in my hurry to save time and money can i swap the 8lug 410 front disc set up with my 6 lug set up--meaning mount it[410] and use my 6 lug spindle setup on it until i can afford the new 8 lug discs and calipers and pads?
depends on year and what trasfer case you got.as long as you dont have a 203,keepin it in 2 hi will be fine.make sure you dont have auto hubs as it may still spin the front diff.may not be a problem unless you accidentally put in in 4 wheel.you have to use your backing plates and everything else from the 6 lug outers and of course your 6 lug wheels.when you switch over you can reuse your caliper but will need to push back the piston to fit the new rotors and pads.other than that you should be fine.if i missed something hopefully someone else will answer.
thanks
i just wasnt to sure of the 8 to 6 switch on the 410 its certaainly not my top choice but for now itll save me some cash---and i do know that ill have to carry 2 different spares ---but its not the first time ive heard of guys having to do it------in fact this site is where i learned to do it :bow:THANKS PAL-------------I LOVE THIS SITE!!:waytogo::woot::woot::woot:
