I have a 454 from a 87 Suburban with regular peanut port heads that I will build for my K10
my rig is a 1986 K15 that has
14BFF + 10-Bolt ( 3.73 gears )
SM465 + NP205
33" tires
total weight around 5000 lbs
it is used mainly in sand dunes and on the street
this is the combo I am thinking in
and I need your advice to decide on which intake and cam to use
around 9:1 compression
Edelbrock 750 CFM carb or Q-jet
Hooker long tube Headers + dual 2.5" exhaust with Throush mufflers
Heads: stock peanut heads but, does it worth to put larger valves in them ?
Intake:
Performer 2.0
http://store.summitracing.com/partdetail.asp?part=EDL%2D2161&autoview=sku
or
Performer RPM ( needs adapter to use Q-jet )
http://store.summitracing.com/partdetail.asp?part=EDL-7161&autoview=sku
which one is better in this application ?
and what about Summit branded intakes?
http://store.summitracing.com/partdetail.asp?part=SUM-226022&autoview=sku
http://store.summitracing.com/partdetail.asp?part=SUM-226024&autoview=sku
Cam: I would like it to have nice off-idle and mid range torque + a little rough idle and I won't rev it past 5500 rpm
Lunati voodoo 60202
Duration @ 050 inch Lift: 219 int./227 exh.
Adv. Duration: 262 int./268 exh.
lift: 0.530 int./0.542 exh.
Lobe Separation: 112
RPM: 1,400-5,700
http://store.summitracing.com/partdetail.asp?part=LUN-60202&autoview=sku
or
comp camp Xtreme Energy 4x4 11-235-3
Duration @ 050 inch Lift: 218 int./226 exh.
Adv. Duration: 262 int./270 exh.
lift: 0.505 int./0.515 exh.
Lobe Separation: 111
RPM: 1,400-5,400
http://store.summitracing.com/partdetail.asp?part=CCA-11-235-3&autoview=sku
they are very similar but, based on searching in other forums I believe that the Voodoo series have newer designs compared to Comp cams and they make less noise than the comps
also I've read complaints about comp cams with wiped lopes after initial start-up even after following their instructions
so which one do you recommend ?
any input is appreciated
thanks
SM465 + NP205
33" tires
Intake:
Performer 2.0
or
Lunati voodoo 60202
RPM: 1,400-5,700
or
RPM: 1,400-5,400
thanks
now I think I will use the peanut ports
