RoTuN
Registered Member
Here's the block............Gen VI
Anyone know the significance of the 6 bolt timing cover?
casting #..............
Heads = oval or peanuts?....................... casting # 10114156, will be ditching these for 110cc chambers to boost compression a little for higher elevation...
Going to run a SMI Q-jet
Going in my '74 K10
Will not be towing
Will not be rock crawling
Would like idle to 5000 rpm range
Will be used from 6000'-12000' elevations
Bottom end is newer, won't be touching it!
What heads to put on?
What cam?
Going in my '74 K10
Will not be towing
What cam?
