OK so the Crew cab had the Air pump removed and tubes with the exhaust holes plugged. Looking at wiring it shows two connectors one for each Left and right air divert solenoids . I am not good at reading wiring stuff. Does any one know what all would of come off the air stuff and what might of been plugged in to carb?
I'll try to take a picture of what I am looking at but have already found the hot wire to aux cooling fan relay cut. The aux cooling fan switch on pass head has juice to it. Not sure if it should. the yellow is hot and the squiggly is wire that was cut. I check fuses and the wires to fan no juice the relay I could not get un hooked. Not hacked as bad as some trucks I've seen but still need to see what is what.
At least for a HD emissions rig, which generally were pretty basic.
) are from the AIR diverter valve (33) and the area on the fire wall where the two brackets are that normally is the fuel pump relay are Check engine Lamp relay (100) and the missing one on yeller is the AIR Diverter module (99). I didn't climb in to the motor area today because my leg was hurting pretty bad but if I feel better I pull the air cleaner off and do some more figuring of things.
