The Hellcat Blazer
Just a budget Blazer build out of control
AT LONG LAST!
I've been extremely busy at work, and hammering the K5 after work till ~10pm. No time to post. First start Thursday went great. Friday was an 11pm pull at work, so nothing got done. Just ran the truck a few minutes at a time Thurs and Fri.
I locked tf in today. Made some fan mounts for the Windstar fans, got the radiator and heat exchanger installed. Got the fenders on, routed and re-connected all the wiring. Lots of little stuff, a solid 9-8 day working. Some moderate throttle blips and a short drive, then the first oil change. Drove it to the shop to put the new wheels and tires on. I LOVE them! Slightly wider offset than the others, but not crazy. 10/10 imo. Now I have my 3-500mi breakin, then we can let her eat!
View attachment Snapchat-330797296.mp4
I forgot how awesome my sound system is in this thing. And the best part? I can actually have days off again! Lol. No more second job after work every day, and every weekend. Just some hours cleaning and re-organizing the wiring, and I want to make a custom cold air box for the blower. I may even upgrade to a modern hydroboost, if I snag a good enough deal on one. Then to weld on the new rockers and start cleaning up the bodywork for paint. But all that is at my leisure, and none of it has a timeline or a deadline. My only task I NEED to complete by the end of summer is to paint the Nova, which is only a few hours of sanding away from being ready to spray. Then the Vette 5 speed swap/rewire/engine reseal is the winter project.
That’s awesome!
Thank you! I have some cool ideas for what to do with the airbox, so I'll post up if I get anything going. I gotta play around with some Cardboard Aided Design. Can't believe I have over 200 posts on here, this went way further than I ever expected. I tried to document every little thing in the event someone comes looking for help. Things will definitely slow down though
Don't baby it, don't go to redline, but don't baby it, over half throttle for many short bursts while keeping the RPM around 4500 or less are best for ring break in, they need cylinder pressure to force the rings out into the cylinder wall and seat in, if you just baby it or idle around everywhere, they may not seat in. Good job changing the oil right away.
I did my first full pull with 100% tps within a mile of swapping in the crate engine 10 years ago. :haha:
Other then the cam bearings showing a little wear it looked amazing inside when I pulled the heads.
There is a huge divide in the performance community between "proper breakin is critical" and "break it in how you drive it". I'm typically a "proper breakin" guy until I turn the key for the first start, then I quickly become the "what's max boost feel like" guy. I've been limiting myself to 50% throttle, and I've only seen as high as 5psi once. We'll see how long that lasts! Lol.
I do say for breakin if you asked floor it or baby it and nothing in between I would pick floor it every time.
I saw a buddy, he was the one that said I couldn’t do the swap in a weekend. Had to, I drove it normal for a few weeks then the shenanigans started.
Oh so true!
There has been this debate for decades, however, with modern material science, cylinder finish measurement advancements, oil anaylsis, and actual testing, the data and evidence is showing that you want plenty of cylinder pressure to breakin the rings, without the increased risk of immediate high RPM stuff. You also want to change the oil almost immediately, then 500 miles, then 1500 miles, then normal oil change intervals. Babying it around is not good for breakin, and the data shows it now. But at the same time, it's a little safer to not rev the piss out of it until everything is bedded in and you know its good to go.
If you notice a lot of the latest videos of the new ZR1, Chevy limits the power and RPM until 500 miles. Then it's wide open and full redline. But that doesn't mean to baby it, I get on new engines, even WOT, for short low RPM bursts. Which when you have decent power, that means very short bursts. :D
I did an oil change at 500,1000, 1500 and then 3 thousand. But it gets an oil change once a year now which I would be surprised if it gets 500 a year. When I really drove it a “lot” I think I got close to a thousand. The Holley has been on for 5 years and I’m at about 3800 on it.
I just checked, they work fine on my phone. So its definitely my computer missing the correct file or something.
Using Mozilla Firefox on pc I get error messages for videos, sometimes if you open video in it's own tab it will play.
Great build definitely not a cookie cutter
500mi down, and she's ready for some rips. Oil pressure is great, oil looks great on the dipstick, and there is 0 liquid collecting in the catch can. When coming down from speed, it's pretty hard to keep her straight and she's fairly squirrelly, likes to wander a bit. Upon further diagnosis, I have substantial lateral play in my (1 year old) steering box output shaft. Big problem, so I'm getting some upgrades. Got a 3 turn RedHead steering box (already arrived), all new power steering and hydroboost lines, and an XJ steering shaft going in. I need this thing handling tight at 120+mph.
View attachment 2026-06-17-205826162.mp4
View attachment 2026-06-17-210253700.mp4
What is everyone liking for shocks? Currently on Black Max's. I have no complaints, but it is my understanding that Fox shocks are a LARGE step up and a worthwhile upgrade. I'm only looking at upgrades because I know I won't want the Black Max's forever and I need to get my limit straps/bumps installed. I'd rather get those set up with my long-term shock specs factored in, so I may upgrade relatively soon.
I'm thinking Fox 2.5 IFP's up front, Fox 2.0 IFP's in the rear. I don't need reservoirs (unless I find some for a STEAL), and I feel that setup is as much shock as I'll ever need for this particular truck. I'll happily hear opinions! I'm not super knowledgeable in the suspension arena. Do 2.0's and 2.5's bought from ORD come with their valving, or are they all off-the-shelf?
I will try and get some clips of the exhaust/more stuff. I haven't welded the H pipe in yet, but I don't feel like I'll have time for a couple weeks so I'll stop waiting for that. Got a new aluminum radiator on the way as well. The original one popped a leak, the fix didn't hold, and it'll look clean with a new unit in there.
Coilovers is my vote, but get the best off the shelf shock you can get the fox’s are nice.
Your crazy for taking this thing to 120mph my truck lifts the front end at 110. :haha:
Redhead box went in Saturday with the XJ steering shaft and all new lines. She did great for 15min, then steering went intermittent, then lost all steering and brakes! 3h of testing, draining, bleeding, and inspecting later, diag'd a failed power steering pump! The new C6 pump landed today, got her in, and she has steering back. The tighter shaft and box have made some worn tie rod ends (and potentially all joints) more obvious in the steering feel, which is a bummer because everything is only a year old and she has been lightly used! Only racing and a few jumps.
New aluminum radiator has arrived as well, so I won't have to toss 2 gallons of water in every time I go somewhere lmao. Hoping to get the new rad and new fan mounts handled in time for Sunday's cars and coffee.
I was really looking forward to getting the H pipe installed for less of the true-dual exhaust sound and hear more of the equal length header notes, but I can't fit an H-pipe due to my suspension travel and front driveshaft interference. Kind of a bummer, but less work, so oh well. I still love my side pipes!
Still undecided on shocks, are Fox 2.5 front and 2.0 rear REALLY worth the cost? ~$1300 by the the time I get everything installed. Anyone running Fox's?
Are you talking about coilovers or just really nice shocks with the leafs?
If you're actually going to jump it, you'll want axle trusses and bump stops as well. Doesn't that still have a rear 10-bolt?
It has a 12, with a posi and chromoly axles. Bumps will also be sourced and sorted if I need them, for now I'm just looking for shocks and I'll see how long my poly bumps last. If I start a) getting a lot of offroad use out of it or b) even hitting the poly bumps, I'll upgrade to proper hydraulic. I've only hit a few small jumps out here on some of the trails, going across roads etc. I won't be hitting any 20ft gaps at 70mph lol. I also have a built 9" with a locker on standby, in the event this 12 bolt decides it has had enough. Ideally, this 12 will hold up and the 9" can go into the next truck
