I am needing a 1 piece rear main seal flywheel for my L29 install. Please note externally balanced 454 flywheel. Thanks
I should have one but if you have a part number it will help me pick it out of 6 I have.I am needing a 1 piece rear main seal flywheel for my L29 install. Please note externally balanced 454 flywheel. Thanks Ron
I am in the process of determining part/casting numbers. @Larry used 14096987 { not sure if this is a part # or casting #} on the internet so far I have came up with 10101171n {casting #} which is supposed to be part # 12556918. Confused yet?? I'm not done!I should have one but if you have a part number it will help me pick it out of 6 I have.
One is a 6.2 also external balance so I don't want to confuse...
Thanks, RobI've got to check the number at work tomorrow, but this is what I came up with at home. 12556918. No listing of a different flywheel between cast or forged crank.
Thanks Larry, I will get it ordered. I have always used Luk clutches, what do you use/recommend?Lol, that was a part number. Casting numbers are worthless most of the time.
14096987 is the GMPP part number for the 454HO, which is essentially the same as an L29 as far as the generation of the block. Not really sure what the difference is between this and the stock production flywheel number Rob listed other than a GMPP part always cost twice as much. This part number came from the instruction sheet that came with this crate engine many moons ago.
12556918 this is the stock flywheel. I’d go with this one as it is much cheaper. Rock Auto shows them for $60. Can’t beat that.
