red EOD
Looking for ideas and doing some research on the big block since I'm much more familiar with diesels
Engine is a 1995 454 TBI all stock. Curious on upgrades for it with the main operating rpm range being idle-3200 without destroying the fuel economy which is currently 10mpg empty, not sure towing yet but goal of 8mpg pulling 10k camper trailer. Able to run 87 grade gas ideally.
Naturally aspirated vs forced induction? Would a low psi of boost still require higher grade gas given the compression ratio on these engines?
