trevmountain
Hey Guys. I've got a cherry 84 1 ton with a built 454. Bored out and decked with the goodies. Motor has about 10,000 to 15,000 on it. I bought the truck a year ago and it runs great and has a ton of power the only problem is that it's using a butt load of oil. A lot meaning a quart every 200 to 300 miles. Here is what I've determined so far.
1) Truck does not smoke on start up or on acceleration throught the gears ( I have had people follow behind me looking for smoke)
2) Motor does not leak any oil
3) It's not pulling oil through the PCV
4) Truck runs great.
The pictures I've enclosed are of the truck, motor and the recently pulled plugs. These plugs only have about 2000 miles on them and as you can see they are super fouled. Based on this I would assume rings or valve guides but with no smoke at anytime it's odd. Also not so sure these plugs are entirely oil fouled. They appear to have alot of carbon build up as well..??
I need some engine gurus
