454 or 500 cadde ???????
Donovan let it be said that I really respect your style and attitude.
now then, there is something seriously wrong with your neighbors chevelle.. 502hp and even more torque should take any 35-3800lb chevelle into the 12's, and I THINK (cant back this one up) that Ive heard of ZZ502's busting chevelles into the 11's.. Its been a while since Ive frequented team chevelle but there are many dudes with the zz502 in their chevelle, its a mean engine and with the proper tranny, rear gears, tires, driver, etc, they'll give most well built <454" cars a run for their money.
intake valve diameter is important, no doubt, but I dont think that you can compare two stock motors, period. regardless of intake valve size and stuff.. we're really not talking stockers anyway.. there were stock 350s making under 150hp but there is a lot of potential.. since were talking about making power, we need to talk about what kind of power we are trying to make. 2.02 or larger valves on a small block chevy will make huge horsepower but for lower engine speed air velocity, the small valves might be a better choice for torque and bottom end power.. its all about breathing.. why do you think a 396 or 402 big block will crush a 350 or 400sb in most cases? its not because its magically a big block, its because it can breathe, and the bigger intake runners, intake valves, etc, all contribute. So- when I complete my sb400 buildup, I will be using aftermarket heads with 2.02 valves (at least) for maximum breathing potential.. 2.02 on any 400" mill is really not "large" anyway.. even for a 350 I think its a good size. okay getting off topic a little.
suffice to say that in order to compare two differnet motors, they have to be built to the same specs (carb, cam, etc) to really do a comparison, and even then, I dont think its right.. where do you draw the line? there will always be someone with a smaller motor but a better setup that will spank you, negating any comparison in favor of your setup.
on a related topic I used to know a guy with a 70 el camino that had a LS7 454 bottom end and he built it up from there.. the advertised output for the LS7 was I think 465hp, and he dyno'd at a little more than that at the rear wheels. that car was mean, and he was running mid 11's on a test n tune one day, and they wouldnt let him run a second time because he didnt have a full roll cage, etc. To make my point, I dont think you can compare based on that info... and for that very reason, my main point about the advantage a chevy has over a cad, is that it will be easier, cheaper, and will make just as much power because of the huge availability and aftermarket for the motors... correct me if Im wrong but I dont remember looking thru summit and seeing a $100 performer RPM for a cad, nor do I remember anything about Thorley making headers for 73-87's with a caddy big block :/ i think you have to consider all points here..
enough rambling :)
mike
ya know they make a flywheel for a caddy. $300 though!
<font color=blue>American Pie 2-"Have you seen my flute?" "Yeah, I stuffed it in your box."</font color=blue>
The Olds 455 is 4.125bore X 4.25" stroke with 6.75 rod
Donovan
Nitro Fumes makes me Horrrrny
What? No 455 Buicks? If I remember right a "Stage One" (factory HP) had 510 ftlbs at only 2800 RPMs!
Real trucks don't have spark plugs!
Actually I did run it in the 1320 with my almost stock 454. Problem was that my rear crank seal blew out and smothered my clutch by the time I was at the track. I could hardly put the pedal down in 3rd ger (outta 4) leaving a stoplight. It was so bad I couldn't even get the tires spinning in the water in the burnout box! Managed a 17.8 in the 1/4 mile with that... There was a stockish 1/2 ton shortbox that ran a 16 that day with 33's.
Squash
<a target="_blank" href=http://www.trailrunners4x4.org/users/realsquash>http://www.trailrunners4x4.org/users/realsquash</a>
I love the post personaly... awsome info and it has been a while since I have talked real hard core race setups. My main concern is cylinder heads. Now the caddy motor is gonna be a sweet motor for a truck and street rod, but my next build up is to get back into an IHRA or NMCA class again. I can see Donovan's nova easily getting to 11 flat w/ some gutting and another item no one has mentioned on any of the posts is what kinda suspension setup and what size tires? Drag radials or slicks? and there about a million other items that come into play.
But my main concern is the heads. I'm not a machinist so I'm not sure exactly what can be done w/ the stock ones. I have never seen any aftermarket ones, but if someone knows of some let me know. But I see no alum heads and limited availbilty of parts... that I see as a problem for 10's and beyond (yeah call me crazy if ya want... I AM
. One of my bud's runs a car in NHRA Super Gas that runs about ten flat on a 509 so gotta keep up with the Jones' LOL
Also I'm wondering what is the fastest caddy car anyone has seen? any links to it would be awsome.
-Mikey
1987 Chevy K5 Blazer- 350 TBI
<a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
That will probably be my nest step. That pontiac 400 is just stting there looking for a home. Just going to wait till the 350 dies first in my blazer.
86 Jimmy 4"lift 35"MTRs Other cars 69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
I saw a couple of pics and a write up on a 500 Caddy in a VW bug...
He used an Eldorado front sub frame and grafted it into the back end of the bug. The thing looked frightening...
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
Hey man you should do what ever you want. You shouldn't have anybody to prove anything to except yourself!!!! Research it a little bit (facts though) and think about what you use it for and what kind of gains you would want out of it, then simply go with that decision there is no need to try to keep up with "the Jones" per say!!!! Just my thoughts though, you do what you like with everybodys advice here, you have plenty of it!!!!!!!!!!!! Later
Thanks,
Greg Gayman
Hawglet
Stovie
[email protected]
To go off of what Mike reeh said;
"to compare two different engines, build them to the same specs"
Well thats why I was asking for the Bore/Stroke/Rods. Useing the "over-square" and "under-square" principals, you can get an -idea- of how the engines going to preform.
-Short stroke, big-bore = a rever, lots of upper-end H/P, like 327s and 302s
-Long stroke, smaller bore = a stump-puller, lots of low-end torque. Like a diesel (kinda)
Both have their applications, and both need totaly differnt cams, so doing a "back to back" test with the same cam/heads/manifold etc..., just wouldn't be a ligitamet test.
Thats why, figureing out the fundementals is so important.
<font color=purple>Sometimes life just makes you want to say,
"F*bleeeeeeeeeep*K !"</font color=purple>
<font color=blue>Twiztid</font color=blue>
Twiztid. Look up I put the bore/stroke and rod sizes up there
Well Mike it is a long story on the head and valve size and I will not get into it unless people on this board would like to here it. Just let me know and I will try to explain.
First off I live here in the Denver Metro area and you lose about .8 to 1.0 seconds in the quarter mile compared to sealevel. So beening that, that Chevelle I talked about should be running low 12s. It is very hard to get a engine to make power up here Mike. I don't know where you live but if it is not in Denver, Cheyenne or Albuquerque it is hard to explain how hard it is to run those numbers. That is where I am coming from. There is no replacement for Displacement. Next thing you talk about is price of the caddy engine parts. I can see where it might be a little more expensive but look at the start up cost of a 454. Around Denver the going cost of a 454 is around $500 and the going price for a Caddy 500 is $100 so That is where I can make up the money. If you have any questions let me know. BTW I do know a guy that has a 455 Olds in his early 70 Chevy truck. It is a 4x4 and I believe it has 3.08 gears in it with 31" tires and it runs a Low 17.0ET. If anyone wants more info I will try to get a hold of him this week.
Donovan
Well, I gotta throw in my .02!!
I'm a BBC guy, always have been, and always will be!!
The 472, 500 Caddy's engine numbers impress me, especially for the stock set up.
The 455 Pontiac's, I had one in a station wagon, man, those things are like "unbreakable". That car FLEW!!! All 6000 lbs. of it!!!
I have a buddy here in town who is pure GS nut. All he buys and thinks about are the 455 Buicks. I cant say much for them because I have never witness one do anything.
I have seen plenty of ALL the sizes of BBC's work. I switched over to the BBC's after blowing a 350 SBC once. Never looked back since. (until I bought my first Blazer - which has a 305)
The choice of engine size and brand really lies in what you have seen, experience, and believe will work best for you. You can take info from just about anybody in the world and it may or may not be the best set up for your Blazer.
So, for the choice of motor, as they say, "keep your GM all GM". My opinion, that means, "keep your Chevy all Chevy".
<font color=blue>"Ya don't have to beat it, ya know!!!</font color=blue>
<a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>http://coloradok5.com/gallery/thatK30guy</a>
I guess your higher altitude does come into play, never really considered that, being in san diego myself..
One thing I was wondering is this: what kind of truck was that guy driving, that weighed in at a mammoth 7 thousand pounds? My 77 K25 is a pig at 5500 with me and some gas in the tanks.
mike
Pontiac:
350- 3.876 bore/3.75 stroke w/6.625 rods
400- 4.121 bore/3.75 stroke w/6.625 rods
455- 4.152 bore/4.21 stroke w/6.625 rods
Olds:
455- 4.125 bore/4.125 stroke w/???? rods
Caddie:
472- 4.300 bore/4.060 stroke w/6.75 rods
500- 4.300 bore/4.304 stroke w/6.75 rods
Ford:
302- 4.000 bore/3.000 stroke w/5.155 rods
351- 4.000 bore/3.500 stroke w/5.956 rods
460- 4.4(?) bore/3.850 stroke w/6.605 rods
4.6L- 3.572 bore/3.543 stroke w/5.933 rods
Chev:
305- 3.740 bore/3.480 stroke w/5.70 rods
327- 4.000 bore/3.250 stroke w/5.70 rods
350- 4.000 bore/3.480 stroke w/5.70 rods
*383- 4.030 bore/3.750 stroke w/5.70 rods*
400- 4.125 bore/3.750 stroke w/5.565 rods
454- 4.250 bore/4.000 stroke w/6.135 rods
502- 4.470 bore/4.000 stroke w/6.135 rods
5.7L/346- 3.89 bore/3.622 stroke w/?.??? rods. 10.25:1 comp. (LS6 vette engine)
4.8L/293- 3.78 bore/3.268 stroke w/?.??? rods. 9.45:1 comp.
5.3L/325- 3.78 bore/3.622 stroke w/?.??? rods. 9.45:1 comp.
6.0L/364- 4.00 bore/3.622 stroke w/?.??? rods. 9.40:1 comp.
8.1L/496- 4.25 bore/4.370 stroke W/?.??? rods. 9.10:1 comp.
D. 6.6L/403- ?.?? bore/?.??? stroke w/?.??? rods. 17.5:1 comp. (300 psi cranking comp.)
D. 6.5L/396- 4.060 bore/3.820 stroke w/?.??? rods. 20.2:1 com. (370 psi cranking comp.)
<font color=blue>Twiztid</font color=blue><P ID="edit"><FONT class="small">Edited by Twiztid on 12/27/01 08:58 PM.</FONT></P>
The truck was a Dually truck with a Dana 70 rear and it had 36" tire. It was quit a beast.
Donovan
I am no expert by far this is my opinion on the subject I have run 4.3's 305's 350's 400's chevy and pontiac , 455 pontiacs,
454's, 472's and 500's my 3 favorite motors are without a doubt the 400 sbc 455 poncho and 500 caddy. Not taking anything away from the bbc, it is great motor also, but it seems a lot of people have them, It is great to smoke someone and after they flag you down, pop the hood and see a sbc, or a caddy or pontiac. there were a couple of years that sbc 400's had 4 bolt mains. You can also go with splayed, splaid ? caps for added strength. 455 poncho's are becoming unbelievably rare, with cam and intake and good exhaust, they will impress you for sure. If you can find a 70 eldorado 500 motor, grab it. that motor with a edelbrock intake
and 850 holley will boil 44's on pavement, no crap I have seen it done. I also know a little birdie who is involved in Edelbrock R&amp;D. Performer RPM Cadillac heads will be in production this coming year. And when that happens.....Watch out!!
IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
No I am not on dope, nor do I see the need to digress to name calling. Every 500 or 472 cad motor I am aware of is currently residing in a junkyard or dilapidated old cad in some farmers field. Therefore by definition junk. Neither am I trying to deny what any of these motors are capable of. My point is that more perfomance can be gained from other areas than the motor depending on your situation, much more cost effectively. Furthermore, if you had ever built a motor which it appears you have not you would realize some of the difficulties and problems encountered that cost you far more than mere money, often your sanity and even the occasional marriage lol. Myself and a friend of mine recently built a full roller racing 454 for his cj5 (yes I realize the lunacy of this) which the total cost was in excess of $12000.00 and we started with a $500.00 runing motor from the local "Junk yard". This of course is an exception, and you can have a perfetcly running motor for far less. Also the costs I am associating with this represent the median of vehicles Ive done in the past and was assuming a built motor above and beyond a running stocker and was taking into account the time as well as the parts not directly involved in the motor but which will most likely be destroyed as a direct result of its application. I believe Mr. reeh has eluded to this as well as the application of the aforementioned engines in some of his posts. I am however not trying to implicate that he supports my view nor have I solicited his or anyones allegiance. So while you can pick up cad motors for less and they certainly capable, my message is simply buyer beware the thin cany coating can wear off rather quickly. In closing I would like to ask that if you wish to call me names please send me a private msg or email me as I put true info in my bio and am not hiding in cowardice behind false info. I ask this because some people are actually K5 owners unlike you (at lest what is represented in your info) and have legitimate purpose in using this service.
Subvert the accepted paradigm.
I am by NO means a mechanic, but I do have a Pontiac 400 in my Blazer. I love this thing to death. It has never failed me. It is pretty much stock with the exception of the Edelbrock (sp?) performance kit. This thing purrs like a kitten. With as much horse power and torque this thing puts out I personally will never install a big block. Don’t get me wrong. Big blocks are great and make the world turn. For me this 400 Pontiac is what the doctored ordered. I would be interested in anyone that has links to sites that sell Pontiac performance kits and conversion kits.
There is a VERY fine line between hobby and mental illness
