klowninc89
Ok guys picking up a 1995 454 block and heads probably will rebuild it. Bit my question is I have a 1990 K5 all stock still using fi system. I want to continue to use fuel injection what do I all need to do? Thanks guys.
I have a '94 454 TBI and it is the high fuel pressure system. I was having problems and finally figured out it was because of low pressure.
The motor is in my buggy, I'm running a th400 trans. I ended up getting a stand alone kit from performance fuel injection.What year is it in? And what did have to change?
