454 TB and plate
1-tonmudder
In a junkyard somewhere
This is a factory TB and adapter from a 89 K30.The plate has the spreadbore or Quadrajet pattern on one side so you can run a factory or aftermarket intake without buying a late style TB intake.TP sensor is missing.$200 and the ride.
A ECM and harness,electric fuelpump,and if you are going to put it on a 350 youll have to change to 350 injectors.Depending on whose harness you buy you can still run your HEI or change to a late model small cap dist.
I am running this set up on a 350 with the small cap and a AFI harness and chip.
You have to have the Quadrajet style intake it will not work on a Holley bore intake.
