Anyone want to post up some favorites for a 454 TBI cam?
Dad is looking at buying one for his upcoming TBI swap, and I have no experience on the big block setups.
Conditions/Specs:
Stock 454 TBI/injectors (will tune as necessary)
Essentially a 454 rebuilt "stock". (no idea what heads, I can ask. Intake is an Edelbrock performer IIRC)
6000lb K20
465/205/4.11's
Tows a trailer over mountain passes
Cruise @ 70MPH=3000RPM
Never sees over 4000RPM
All freeway/logging roads/around town
Emissions not a concern. Mileage is. (like it's going to ever be "good"
To be honest I don't know as even the "RV cams" are something he'd need. His trailer is probably 7500lbs or less, and trading any off-idle performance in that heavy of a truck kind of sucks. The cam the rebuilder put in it was the only thing that was performance related, and is way too high of a power band for how he uses it.
As it's driven, it's probably 25% trailer towing, and 75% unloaded.
Conditions/Specs:
6000lb K20
465/205/4.11's
)To be honest I don't know as even the "RV cams" are something he'd need. His trailer is probably 7500lbs or less, and trading any off-idle performance in that heavy of a truck kind of sucks. The cam the rebuilder put in it was the only thing that was performance related, and is way too high of a power band for how he uses it.
what a choke down in port size.
) and PERHAPS the stock EFI cam. Probably not an issue on port mismatch since there is no step, however I can see where it would kill port velocity at that point. Since he is going for low end power, it can't be any worse than if the ports were large all the way through.
