Vetteracerx
I have a mild 454 and a monster 700r4 in a 1991 K5. I ordered a custom chip and am having bad luck with it. In closed loop it runs ok except for some detonation at 3/4 throttle. I think I can fix that with fuel psi and bigger injectors that I allready have. In open loop it blows fuel out of the exhaust bad. It flodded itself so bad fuel pooled up on the throttle blades and caught fire when it backfired. I bought a pocket programmer and other stuff from GMC truck here http://coloradok5.com/forums/showthread.php?t=296748
I tried to save a bin from the custom chip using the pocket programmer in tuner pro but I must not be doing it right.
I have a wideband o2 installed along with a heated o2.
open loop air fuel ratio is like 10 to 1.
closed loop crosses rich and lean and seems good.
Is it possible to work with the program that is on my chip or do I need to make a new one?
Thanks guys I have been reading all night and I cant find an answer
But not neccessery...
