So, I've somewhat torn into my 454. Mainly to inspect the intetnal condition, and replace seeping gaskets.
I'll also be converting this thing to T.B.I. So I have a couple of questions about that as well.
I'll start with the more serious issues at hand.
1.)I pulled the intake and noticed that the Cam was slightly off center of the lifters. Is this normal?
2.)Then. I pulled the timing cover off and noticed it had one of those poly cam gears, are they ok? Or should this be converted to cast? What are your opinions on gear drive?
3.)After removing that, I noticed that there wasnt a cam retainer on the front of the block. Not supposed to be there? (having one would also mean that the cam would have to be farther back in the block, thus mis-aligning the cam and lifters even more) Could it be the wrong generation cam?
4.) what are your opinions on these flat tappet cams? good enough? Not looking to turn high R's or anything...
5.) Since I'm going to run T.B.I. Iremoved the mechanical fuel pump of course. Is it ok to remove the pushrod from the camshaft to the pump? (wasn't sure if it would affect oil pressure in any way)
6.) Should I be changing the cam when swapping to injection? Not sure whats in it now for one. This was a Marine motor, and I know they changed out the cam when they converted it to an automotive app.
Thanks for all of your input!
