bigbadchev84
well I just swapped out my465/208 for a 465/205 combo in my 72' blazer today to fix my driveshaft problems.
It started off that my help cancelled on me first thing this morning and I was up to pulling and installing these heavy fuggers myself. My first thought was-Ill just pull the top cover and see if the 32spine output is easy enough to swapp with the 10spline output for the 205, That way I wouldnt have to try wrestling the tranny.
I took all the top cover bolts of my soon to be installed 465 and couldnt get the cover off, I got the gearshifter and tried all the gears to see if it needed to be in a certain one to remove it-No worky, So I undid the tranny hump, Wheeled in the cherrypicker and removed the tranny and case, Installed 205 setup- Everything went smooth, I went to install the hump and shifter and went to put it in neutral so that I could install the driveshaft, and I cant get it out of gear? I put a crowbar into the x-case u-bolts and can turn the motor over, so I know its not bound up. The hydraulic clutch is yet to be installed.
Is this a problem or do I need to wait until I get the clutch working?
