465 to figure 8 adapter bolts. Are they drilled into the oil cavity?
shady
1 ton status
iowa
My trans to adapter bolts keep getting loose. And fluid is leaking.
Do those bolts thread into the oil cavity?
I'd like to brake clean the holes, and locktite them.
But I don't want to pull one out and drain my trans either.
I believe they do go into the cavity, but it's been a while since I've been in there. In fact, the seal between the trans and t-case is on the t-case side. So you're going to be losing gear oil.
Kind figured. There were tighter this time than they looked. Only a little drop for a leak, and a half turn on most of the bolts.
Ive tightened them twice before, and seen a drip and what looked like a small gap. But it was an illusion due to the slight offset of the castings.
I still want to do it. But I'll let it ride for now.
Thanks.
