Josue
Registered Member
Hello
I have a 1995 transmission. Its a 4l60e, according to what I have read that the 95 is its own beast with its FCC puslse width modulated or something like that. Feel free to correct me. My transmission was rebuilt years ago. Buy the transmission sat there for years. And is currently making a squeaking, squealing noise from the front pump/torque converter area. Only when the trans is hot. And mostly when ideling at a stop sign or park.
Things that I have done so far
1. Stall test, rpm reach 1800 rpm ish, stock stall lock Idk. Please inform me
2.checked trans fuse. All good
3.checked the trans for codes after driving approximately 30 miles. Nothing pops up
4. Check with a scanner solenoid operation of all solenoids. And I can seen them changing. The force motor or epc or pressure regulator amps is also listed
5. Failing or clogged epc or force motor what ever name it is, is said to cause a squealing of the pump because it starves it of oil. Truck gets up and goes
6. Ohmed out the pressure regulator solenoid and is within specs at 4 ohms. Screen looks kinda dirty. Can I clean it?
Things I noticed. Has a 93 valve body on the 95 trans. Is it compatible? Has all the correct soleniods as far as I can see.
What do I do next? Replace the torque converter? Does it get Ruined? I also haven't checked line pressure as I don't have a line pressure checker . Should I check this?
