4L60e Torque converter in a Bind
What year ls and 4l60e?
If the trans is from the 90's and doesn't have the 12 o clock bolt on top it will need a bushing that goes into the back of the crank to pilot the converter to seat right.
You have not mentioned what transmission this is. If you are doing an LS swap to an older transmission like a T350, then you need an adapter for the torque converter to engine crankshaft.
2003 / LS3 / 4L60e/ NP241C
