What's everyone's favorite manufacture kit? What's the good parts to use.
Transtar, all OE quality or better materials
Use the Borg Warner high energy band, either machine the reverse input drum on the band surface or replace it, it will be warped.A Corvette servo will certainly help on band apply. Be sure and replace the input sprag with a 29 element dual cage design. Invest in the Sonnax AFL valve kit, you will need to have the valve body bored but it is worth it, they are almost always way out of tolerance and will leak vital line pressure. A small TransGo or Superior box kit will help things out, no need to go to extremes. A new Reaction sun shell would probably be a good idea too.
Sounds like a great plan, if I followed every step, what would this trans be rated at? Going to start looking around for these parts and create a shopping list.
Sounds like it should fit my 6.0 thenShould be good for 375-400 Crank HP
You can use hard parts just check very carefully for damage. Clean clean clean then clean again
That's the problem with the torque converter. Can't really get it clean
No sir, a old GM tech will be.Are you doing the trans build yourself or having someone do it?
