4L80-E gurus.....
DEMON44
Low-Tech Redneck
Okotoks, Alberta
OK guys the auto in my '96 is terminal...no hope for revival. I got my hands on a known good very low mile rebuilt 4l80-e for a heck of a deal. BUT........ there are some differences right off the hop that I need help figuring out how to deal with.
#1 - the shift linkage on the good one appears to be for mechanical linkage, and the one in the truck is cableshift. The attachment points are very different........can I change out the shifter shafts to correct?
#2 - there appears to be a different number of sensors on each. mine has one right on the shift shaft bolted to the side of the case. the other does not (Neutral safety?)
I really don't know what the other ones are anyways........can anyone guide me in the right direction. will I had to swap cases? or rob all the good guts out of the low miler and rebuild the one I've got? are the internals the same?
the shift rail could be a easy swap out. nover done a 4l80 one tho. and thay moved the park/nutral switch to there in 95 with the new dash styling and steering wheel setup.
