Masiony
WRENCH-HEAD said:Used when the trans no longer shifts on its own, you shift for it. Originally a race setup now working into the 4wd world. In essence it turns the auto into a stick shift with no clutch pedal. then you would want to run a gated shifter or the likes to make sure you get the right gear.
ok, so that is good because it gets rid of the computer, and its good cause it gives you more control?
