TommyM
My '90 TH400 and the '91 4L80E 3/4 ton Suburbans both have the same ("top to bottom on the right" as you said) piece attached to the column.
However, the long rod that runs from the column lever down to the arm at the trans is a little bit different, with some different angles.
But here's the one that stumped me for a while. The little u-shaped piece that bolts directly onto the trans shift input shaft is not the same. The bolt hole that is "square" on two sides is angled differently such that the long rod would bind when I used the TH400 one on my 4L80E. When I swapped that, everything worked great.
I hope that helps,
Tommy
I hope that helps,
Tommy
