mckustomfab
Here is a ECM/PCM question.
I have a 1991 R/V 3500 (4x4 Conversion) currently I have the 2wd 4L80e still hooked up so the truck is mobile but it is starting to slip. I also have a NV4500 and NP205 that I have been collecting parts for. The NV4500 was originally going to be for my Cummins swap but the time frame on that has slipped some.
Now i said all of that to ask this...
If I swap out the 4l80e for the NV4500 what ecm/pcm problems will i have? I know the '91 4l80e ecm/pcm is different then the diesel or 700r ecm. I have spoken to a few TBI shops one told me it would drive but it would slip into limp mode and only go to around 1200rpms. I also have the parts to install the tone ring into the 205 tailhousing for the VSS. I started researching and after looking at some ECM pin out diagrams I think i have a few Options.
1) Get a "7747" ECM and and connectors and repin the harness while chasing all the circuits to make sure they are correct
2) Buy a aftermarket engine harness that is designed to work with the "7747" ECM and make the needed connections
3) Send out my ECM to be reflashed and then swap around the connectors that are needed to make the 5 speed work with the ECM.
I'm trying to do this without dumping a lot of cash into it because i am still holding out hope that in the near future it will be getting a Cummins. So if anyone can think of a option I missed, or if anyone has any incite on this project i am all ears!
