4wd engine cross memeber and mounts
Babaganoosh
1 ton status
Phoenix Arizona
I'm looking for a engine cross member and motor mounts for a 4wd conversion. Let me know what you got.
is the 50 for the mounts and cross member? Also can you provide pictures?
Pics in a few minutes.
And yeah $50 covers the cross member and engine mount base.
If you want the actual mounts, I have those too for an additionnal $25.
I would have sold these cheaper if it didn't take for ever to grind the rivets off.:doah:
BRB
I know how you feel, I have both of these sitting outside.. but i have no means of pulling the engine for the mounts and frankly I'm tired of removing rivets... I'm not sure if the frame would go nuts if I removed the engine cross member.
And no this is not rust on there just some caked mud :D
The rubber mounts are nice and tight.
Is the cross member bent/dinged or is it just the illusion from mud?
If it look bent, it's an illusion, I have another one too in black.
I will inspect very carefully before sending if you want it, I will snap a few close ups too so you know what you are getting.
how much for shipping to a home address for 85027?
I'll take your word on it, no further pictures needed on what I'm getting. I believe in a mans word. :D
I will check and get back to you.
with or without the engine mounts?
OK, cross 4wd cross member plus the slanted engine mount bases $50
engine mounts proper $25
shipping Fedex ETA end of business day 2 $25
If that is OK with you, PM me your info and method of payment.
I can have this ready for shipment as soon as I recieve an OK from you.
by the way I cleaned up the cross member that I took a pic of and it had a small crack, which you could easily weld, but since I have another I am shipping the other.
OK bad news.
Let me know what you want to do:
Here are the pics, both pieces have the same crack, I am willing to bet it's a common weak point and most people don't even realize they have it, and now that the piece is out is easily repaired, I will take out $10 for you fixing it if you still want it.
So $90 shipped to you:
I might wait and see on the cross member. Are you looking to get rid of these in a hurry? It might be until next weekend I can inspect the one I have.
I just found out I have to replace the fascia board on the house tomorrow before they roof it.
I have had them for a while, and they will be here until someone wants them, all my frames are already 4wd.
I will weld these and have them ready for any potential buyer.
No worries here.
I removed my cross member and it seems perfect. you wouldn't happen to have a removable trans tunnel for a automatic 4wd single cab would you?
