doonjumper
I forgot to mention single diaphragm or double. Seems to me that a double dphm would give a smoother "push" with larger brake system than a single would. Just my .02.......could be misinterpreting the basics of the system.
your 1/2-1" shorter means like 3" at the pedal, that's a complete "pulled out of the ass guess" but there is some ratio calculating required between that rod and the distance it takes a 12" piece of steel (pedal) to push it.
Well I see some modification in my future![]()
I tried to do this mod on my last truck ('83 K20 and 14FF w/disc brake conversion). The master cylinder I purchased did not work on hydroboost brakes. So, make sure you specify hydroboost when buying the new one if you need it.
This thread is about a 4 wheel disc master cylinder for vacuum boost applications. Folks using the '99 C3500 master cylinder should NOT specify hydroboost.
I have no idea. I replaced the fronts with K30 calipers and the rears are 3/4 ton.
