87 k5 blazer with a 350. Tcase np208 with a 6 inch lift 4low works onlyNeed more information. What king of truck, stock, modified, which transfer case, etc?
Ok will do thanksFirst thing to do is crawl under it and check the linkage
Yes it's moves freely but it will go into lowDoes the shifter move freely? Too freely like it's not connected? Or is it rigid like it's stuck?
203 is multi part .
208 is just a single lever and rod to lever on t-case .
last 208 i had with same problems was blown up . once i pulled the drain plug i had needle bearing guts rolling out with the burnt atf oil .
I had the tcase inspected and service fluid change and sealed203 is multi part .
Well I don't have any traction on the front wheels, it's snow's here and my back in is fish tailing. I went into a ditch front wheels wasn't spinning. I put it in 4low and all 4 wheels are spinningAssuming it works in 2wd and when you shift into 4 low. Based on that it definitely sounds like the shifter linkage issue. 4 high uses the same parts 4 low will use, with 4 low just engaging the planetary gears but the power still flows through the chain and front output shaft.
Should probably ask this question...........when you say it doesn't work what exactly is happening, or why do you say this?
208 / 241 cant do this . its a solid unit bolted to the floor unlike the 203 and 205 with shiifter boot .^^^was just going to type this^^^
lots of lifted trucks have this issue....
especially with body lifts..... pull the shifter floor plate and take a look while moving the tcase lever thru the ranges.. shifter or linkage may be hitting the body or something else on the tcase or frame.
x2 . ether he thinks he is in 4l but is in fact 4 high or there is a major mixup inside the t-case from the rebuild job . but i have not had a 208 or 241 apart to know for sure .Y’all overlooking the fact that if it has 2h and 4l, that is the full range of shifter motion. So it can’t be the linkage not getting full travel.
It is possible something happened to the detents and he is hitting a partial neutral or something
