79rustyk10
3/4 ton status
Ive been kicking around some ideas for a few days, basicly it would be a 5.3 or 6.0 with matching electronic transmission into my 89 LD K2500 with a SAS thrown in for good measure. This was my first truck and it has been sittin at a friends place for about 4 years now, I lost interest in my k20 shortly after I bought it pretty much, and I would love to get my old 89 back on the road eventually. currently it has a dying 350 and dead 700r4.
the suspension, and drivetrain install doesnt scare me at all, what I am worried about is trying to make modern electronic stuff associated with the gen 3 engine/trans work with the primitive stuff in the truck already.
would there be a way to get everything to mesh with stock gauges? I would get the newer tach dash from a 90's truck, or maybe dump it and go with autometers
. or would the vss signal be the same between the newer trans and the oem speedo?
What about the electric climate controls? Im guessing that is completly seperate from the gauge electronics.
Does an aftermarket harness have the capability to just be connected to whatever I want to use for the CE light or other warning lights?
I would like to keep everything fairly stockish appearing from the first glance, maybe thats too much for my technical skills at this time, maybe I'm just overthinking things right now. I would want this to be a DD if needed, and weekend toy and maybe at times a towrig, so reliability is a must, however the 5.3 or 6.0 and 4l80e would have that covered.
The fuel system should be fairly simple, wouldnt a 96-99 vortec pump and sending unit have the fuel suply aspect covered? it already has the EFI fuel lines so the plumbin would be simple.
And dont recomend a 5.7 vortec swap, I dont like that EFI setup.
Im not a diesel guy either, however I could have Scott build me a copy of the engine in his blazer and leave everthing as is with only a 4L80E swapped in for some beef.
. or would the vss signal be the same between the newer trans and the oem speedo?What about the electric climate controls? Im guessing that is completly seperate from the gauge electronics.
