I have a very unique situation where my '86 K5 (with a 2003 GMC 5.3 LS engine) will suddenly begin "cutting out" like it's losing fuel pressure. Keep in mind that I only see this problem on days 80° degrees and warmer. I can go all winter long (months) without a single problem. On day one of 80° degree weather it cuts out after about 8 miles of driving. Once it starts, the engine slowly cuts-out for 1 to 2 seconds then barely fires on enough cylinders to stay running. It'll take maybe 4 to 6 seconds for the engine to die. Keep in mind that I only see this problem on days 80 degrees and warmer. So, here's what I've tried.
Replace fuel pump relay - I bought the $100+ all in one high pressure fuel pump wiring kit from Summit, properly installed it, and it still did not fix the stalling problem. I can still hear the fuel pump prime prior to starting the engine. I no longer believe it's fuel pump wiring related.
Fuse block relay replace - I've replace the relay that providing power to my PCM, pink wire accessores (fuel injectors, sensors, etc). I've looked at the wiring and none appears to be hot/melted. I'm not popping fuses either.
Rewire ignition fuse block - I really don't want to, but I guess late tonight I'll install a new fuse block I ordered off Amazon and install brand new wiring, terminals, and a new relay to power the PCM, injectors, sensors, etc.
Conditions noticed when engine cuts out:
- 80° (or hotter) temp outside
- Engine starts up again and runs fine after about 30 minutes or so (to cool down)
- Truck's been running about 8-10 miles
- I just noticed yesterday that the computer (PCM) was reset (my check engine light went off and stayed off until an hour later when it realized my knock sensor is bad). Now I'm wondering if the PCM is losing power or may be going out??
