5.3 swap, transmission cooler lines
75K5
Michigan
I am getting close to test fitting the 5.3 in my 75 K5. What are people doing to run transmission cooling lines from the transmision to rdiator? Is there some type of fitting that I can get to screw into the transmission where the fluid lines would normally exit? The factory lines from the donor vehicle were incomplete. Any help is appreciated.
Thanks,
Brian
