mudbog42
Well, I just got my 86 K-5 up and running last weekend. I put in a 2003 5.3l (flex fuel engine). I have been getting check engine codes for the MAF and bank 1 & 2 running lean.
Also when I hook my pressure gauge up turn the key the pressure will rise and quickly fall. So I have to turn the key on and off about 4 times to build enough pressure to start the truck. Once started, it seems to run great. The pressure reads a steady 40 PSI at idle. Not sure if this is too low or not. I read somewhere that the flex fuel motors run at a lower PSI but not sure how much lower. Also if I pinch the return line the fuel pressure will stay, so I thought for sure it would be the regulator. I also took a reading before the regulator and the pump held a strong 75 PSI with the key on engine off.
I have replaced the regulator twice already and it still does the same thing, cleaned the MAF, no difference. Also the o2 sensors are brand new on it. I am not sure what the problem could be.
Any help would be greatly appreciated
