ran for 30 seconds just fine, cut it off due to noise and being in school, this is with choke plate closed
wired choke plate open because electric choke didn't work, i was going to drive it out, when i started it it immediately revved to about 4k and either i cut it off or it cut off, i was in the process of cutting it off if it indeed stopped on it's own. i undid the wire holdling the choke open and tried to start it again, would not start, just try to start a little but not run. has not started since.
