smalltruckbigcid
Since everyone else is doing this I might as well follow along. Todays pictures are of the block after scrubbing and painting it fresh from the machine shop. I set the heads on loose and the intake to see what it looks like clean and almost for real. I won't be using the intake in the picture on this engine because I have an edelbrock thats better suited for this build.
The basic specs are 8.5-1 compression with 120cc heads. The heads have been shaved .015 and larger valves put in, 2.11 intake and 1.77 exhaust. The crank is standard and the cam is a reground stock cam with my own idea for specs. Basicly its .485 lift intake and 218 dur @ .050 and the exhaust is .500 lift and 226 dur @.050. I'm doing a re-ring and re-using the stock pistons and rods.
My goalk for this engine is about 375hp and 550 tq on pump regular. I've deburred the heads and zero decked the block. I should be running about .040 quench and that should help fight detonation. I'm going to advance the cam timing as much as I can for power.
My biggest goal was to get this running for under $1500. Right now I'm at $1200 so there is some room but that can get squeezed quick. The parts and work have taken me 2 years to gather up and I've hunted for every deal I could find just to be a cheapa$$.
