513 gears w/ 35" tires?
This post is swaying me back towards 5.13's. I thought I had decided on 4.88's since I am taking this truck to school with me in Jan.(12 hour road trip). I am running a 350,700R4,NP241, D60, 14BFF, and 38x13R16 TSL's, or at least I will be once I get it all installed. Do you think 4.88's would get any better gas mileage around town? Or maybe the 5.13's would since it would have an easier time getting going?
I doubt you will see much, if any, difference between 5.13s and 4.88s in the city...prob wouldn't see much diff on the highway either. Might as well get 5.13s to get a tad more torque out of it.
5.13 2 reasons . 1 you will have 5.13 gears and 2 you will have better chances at eating the ricers.:p:
hmm, i was goin to swap in 410 gears with my 3/4ton swap, but this is starting to convince me to go with 513s. especially since the d44 i have needs alot more work than i thought, and id have to regear the 10b to match the rear hehe.
how would 513s hold up in a 10 bolt for the front, open with 35-36s?
It's not the 5.13 gears you'd have to be worried about, it's the downstream parts - the inner and outer axleshafts, the axleshaft U-joints, and the hubs.
HOWEVER - If you keep the front diff open, you'll probably be OK. But if you limited-slip or lock that front 10B, you'll be getting intimately familiar with axleshaft/U-joint/hub swaps on the trail...
