mtnman210
1976 Cadillac 500ci Bored .060 over. Now 514 Cubic Inches 8.3 Liters. Fully Balanced.
Pistons - 4.364 inch 8.5:1 Keith black hypereutectic flat top pistons
Crank - Stock .020 grind 4.3 stroke
Heads - Stock 120cc with three angle valve job. Street/Strip valve springs
Cam - Duration @ .050 range 220-228 Valve lift range .525"-.538"
Just had all the seals done from heads to oil pan. Motor shop said main bearings are starting to show some wear and could probably be replaced soon. Motor ran when pulled and had good oil pressure. Engine is ready to run just needs spark plug wires and air cleaner. It has a brand new never run 100 amp alternator and a brand new starter, as well as brand new spark plugs. I do have a Quadrajet carb that goes with it, it is just not in the picture due to the hoist plate being on the motor.
Asking $700
located in Thousand Oaks, CA
Asking $700
