waybad1
I removed the stock steering stabilizer on mine and attempted to drive it to go have the ram mounts welded on. I could not drive a block without a serious wobble anything over like 10mph
Just to say it outloud... the king pins on the D60 in good shape? Good springs?
I don't see anything wrong with the caster. I say leave it.
Other things may be moving if unstable.
On a plus side, I charged the A/C while I had it in the shop and it blows COLD now...![]()
I hate you now...![]()
Longer shackle if I'm reading your specs correctly. Or small shim.
I think I'd go with a small shim.
Well I need a some zero rates in the front to level the truck out. Can you do a zero rate that has the correction built in, or is this something I need to PM or call you about?
A little more caster will help, and another thing would be the upper shackle bushings. Are you still running the stock bushings there at the frame mount? 52's killed mine fast. I upgraded to Kerts kit and it really helped a lot. Even just new bushings if yours are stock will probably help.
