blazin_blazer
all these posts....i post and the thread dies.....wtf.....am i being boycotted? :-)
muddermilitia and i discussed this in his build thread right here, @ post 277 he said 56'' could only run turned 1 direction, so i'm lost now...here goes nuttin..
http://coloradok5.com/forums/showthread.php?t=195380&page=3
Next time could you put the link to the right page? 56s can go either direction. It is more than pointless to flip them around on the front since you are trying to gain space between the firewall and tire. Flipping them around would put actually put the tire closer to the firewall.
i had planned on b52 /56's and zero rate moving axel back 1 1/2'', to get me back close to stock wb .... @1'' forward....now i see all this....so, i can just swap sides w/ front hanger and it would put hanger in front of rad support mount and 56'' will bolt up, and longer shackle will help take full advantage of springs lenght.....but not good for street????
we also talked about crossover and hi steer here
http://coloradok5.com/forums/showthread.php?t=223807
52/56ss on the street are not a good idea in my book but I air on the side of conservative in the safety department. 52/56s and crossover require the removal of the swaybar, increase body roll (read flex) and with the COG you are talking about, limit the K5 to minimal speeds. Also, one of the reasons you do the spring swap is to move the axle forward so that you can space bigger tires from the firewall. Generally, anything bigger than a 40" tire will benefit from this. Skip the zero rate and use the B52 kit (works with 56s too) as seen on the page of the first thread you listed and http://www.diy4x.com/suspension.htm .
so i guess i will just out right ask if what i'm thinking will work...(sorry for hijack, but i think its really same thing you are asking)
i was planning b52/ or swap sides with front mount(??) and 6'' 56'' spring, zero rate used to pull axle back and ?6''? shackels..up front....6'' 56'' springs in back w/shackle flip and ??(what ever it take to level k5)?? lenght shackles in the rear, to get 9-10'' of lift, and still be streetable? oh yea wanted to run the ord or some type of histeer(i've run into stuff in the mud and bent crossover b4...so am i thinking straight or should i just get a 10-12'' stock lift and btw..either way i want histeer and will be running as big a tire as i can afford since i got me a d60f,..maybe even 53'' michelinsw/3 more'' of body lift,...i no you guys dont like the body lifts, but i see no harm in them running in the mud and light i mean light trails or flexing?
I think your plan needs more work. 10" is more lift than I would ever want and would never pass for street legal around here. I'm concerned that a 4-5" lift would get Jonny Law on my tail. What you are talking about would definitely bring the suck. D60 fronts are good up to a 44" tire and even then you would want 35spline outers, chrome-alloy shafts. The R and P might be a little sensitive at this point but basically if you want to go bigger than a 44" , go with rockwells.
Personally, I think you might be better served to start with a 4" lift (or a stock 52/56" spring swap) and go from there. I think you would be pleasantly surprised with what you can do with that. What you are talking about takes some deep pockets and a lot of experience for a result that is limited in its usage. Or better yet, search more about what you want to do. Get a cold drink and a dinner and read this http://coloradok5.com/forums/showthread.php?t=170627 . There are some good ideas on there on what lift and the 52/56 spring swap will do for a rig.
the law doesn't mess w/ us to much around here, so that is not of concern to me, and moving the axel back is what i'm looking at doing, i guess i should have went into a little more detail, i need like a 105'' wb, as i am putting a '69 k5 on a 2nd gen frame and dont want to cut the body,
Must be nice to have lenient law. Still, you and your family/friends are the one riding in it. Not to mention the others on the road. I'm not trying to preach (though I am apparently) just trying to help you out. Sounds like you have an interesting build. I think I am going to need pics to get more of an idea of what you are doing.
what do you mean post the right link? the first link i posted is correct @ post 277/278, and down a few we discuss this(56'' springs). and the second link i posted is where we talk about the crossover/histeer. so with that being said putting the 56'' on bakards and moving the axel back is what i need but how much back are we talking about?(thats what i was planning on the zero rate to fine adjust the axle to where i need it) i was told somewhere that w/ lift springs it wouldn't be as flexy as stock 56''s. i will read the link you posted and thank you, but i am wondering if a stock 10'' lift and a zero rate to set axel back 1.5'' maybe the right ticket for me, b/c iirc the 2nd gen is 106.5'' and the 1st gen is 104.5'', a difference of 2'', so the zero rate would put me at 105'' w/ stock lift springs and still be streetable, its mainly a mud runner but sees some rutted trails where the articulation would be handy but want to be able to drive it on the street, and like i said the cops really don't bother us to much if at all, i have a friend w/ 12'' swamp runner lift and a 3'' body lift and 49'' iroks and never been stopped and its his dd....thanks again
im running ford 57s with a zero rate moving the axle back a inch and a half....gonna run crossover and hydro assist decided not to go full hydro right now
they move the axle foward like 6 inches...it think its 26 one one side and 32 on the other...i have the 3 inch wide ones also so my ferd spring plates will work and i dont have to put washers/spacers in to acommidate for and gap...
thats how much im moving it i just dont see how it doesnt move it farther foward with the short side foward....Nice math (26+32=58)
After reading that thread it says you could move the front axle forward 4" w. a zero rate, 57s, and the front mount relocation. Is that not enough? How much clearance do you need for 44s? I need clarification...
Moving the axle forward isnt solely(sp?) for tire clearance. Many people do it to increase their approach angleNice math (26+32=58)
yepMoving the axle forward isnt solely(sp?) for tire clearance. Many people do it to increase their approach angle
im runnin 42s with the axle 2.5"s forward. I think if I had 44s and the axle was another inch or two forward It would be about 90 degree approach angleThanks. That clarifies it. Between 44s and the axle relocation, it would seem like it could climb a tree.![]()
. just be careful with them, ive heard bout the short side snapping, but i think that was with the 2.5" springs, since u got 3" you might be alright.because of the center pin in location to the axle...think if you had a stock srping in your truck (truck is bone stock) then you drilled a hole for a new center pin 4 inches more foward than the stock hole,you would move the axle 4 inches foward....
