1. they dont in fact this is the worse way to do it. i ran 56" springs in the 52" location on the regular side, not switched. i ran 6.5" shackles and the angle was perfect. tons of droop and plenty of compression. look in my sig and follow the link to my gallery you can see pics of my shackle angle.noahrob said:Hi,
I am pretty sure this is on topic. 1. Why do the shackle flips need to get swapped form side to side for 56" springs? 2. Leper, I don't understand. 4" springs, plus 4" shackle flip equals 5" of lift? Is that becasue of the long shackle?
Basically, I have 6" springs in the front and a 4" shackle flip in the rear. Since I need to get 2" springs in the back, I figured I might as well get some that are longer with longer shackles, but after reading this, I am a little confused as to whether I need rear springs with more arch, like 4" just to get 6" overall.
2. all you need is 2" lift springs. if you go with 2 " springs i go with a shackle more in the 7" range because the spring needs more room to compress and a little less angle.
Btw. 6.5" is the short hole on those lower shackles so they work perfect when used in this application
with that setup that i mentioned, springs fully droop (and it has tons of shackle swing which = more droop) and will completly compress. shackle flips offset 1.5" from the stock hole so its either 1.5" forward or 1.5" back, for a total range of 3"
i didnt pull the clamp the springs were shot enough. also i needed more weight in the back to get the springs to flex all the way which i ditn have. not worried about it now that trucks long gone. im doing a 93 extended cab, sas link is in my sig
