57" Ford Springs Compared to Stock 56, More Lift?
DougK20
Boise, ID
Currently running 4" ORD shackle flip with stock 56" springs (minus 3 leaves) and a zero-rate. After swapping in the 52's up front I need a couple more inches in the rear to level.
Will swapping in Ford 57's give me any more lift than my current 56's? I need 2-3 more inches of flexy lift. Open to suggestions. Thanks!
Unless they're arched more than the 56ers all they are going to do is push you shackles back. COuld take the 57's to a spring shop and have them arched. That'll bring the ends close to 56" and give you your lift
I run the Echobit flip, long shackles in the back, and reversed 57's for the rear suspension... in the front I just put in my 52's w/ a zero rate and I sit almost perfect... the back may be an inch lower than the front...? I am running into clearance problems w/ the tierod / springs so I am probably going to put my zero-rate in the back, put a thin zero-rate in the front and remove the overload leaf in the 52's and then it should be level and cure the clearance issues.
I am not sure how much arch the 56's have to them, but my 57's are pretty flat.
That's basically my question. Do stock 57's have more arch than my 56? No sense swapping if not. There is always blocks, but would rather not. Any other budget minded ideas? Thanks!
My 57's sit dead flat, top on but no back seat.
