Just ordered my rear diff from Quick Performance.
GM Tri 5 1955-1957 Chevy Complete 9" Rear End Package
Housing Center Piece: New Fabricated Big Web (Light & Strong) - $50.00
Housing Upgrades: Drain and Fill Plugs w/ Jack Pad - $55.00
1/4" Heavy walled axle tube (recommended for 600+ horsepower or when welding will be done on tubes) - $30.00
Internal Gusseting (recommended for 800+ horsepower) - $75.00
Leaf Spring Perches *Required: Heavy Duty Reinforced Perches (ideal for high horsepower applications with Caltracs or similar traction bars) - $50.00
Leaf Spring Perches Installed *Required: Yes, Installed in Factory Location
New Leaf Spring U-Bolts: Yes Please (set of 4) - $40.00
New Leaf Spring Shock Plates: No Thanks
Powder Coating: No Thanks - Bare Metal
Enter notes about custom housing width, suspension setup, etc.: 58" overall width, WMS to WMS
Axle Spline *Required: 35 (For 600+ HP)
Center Section Upgrade (for 600+ HP): Yukon Pro N Case, Aluminum Daytona Support, 1350 Billet Yoke - $170.00
Aftermarket Center Section Traction Device - 35 Spline: 35 Detroit Locker - $329.00
Gear Ratio *Required: 4.30
Lube Locker Gasket: Yes please - $20.00
Bolt Pattern *Required: 5x4-3/4
Wheel Studs *Required: ARP 1/2"-20 x 3" Press in - $65.00
Brake Kit *Required: 11" Drum Brake Kit
Braided Steel Brake Lines: Yes Please - $75.00
Universal Parking Brake Cable Kit: Yes Please - $100.00
No idea how long it'll take to get here, I don't imagine this is an on the shelf kinda thing, but no idea on lead time.
I probably could have got away with 31 spline and fewer HD parts but I want room to grow, and have some real confidence that this isn't the weak link in the car.
