i have a set of gm 56s for my truck and a set of ford 57s...whch should i intall where...i was thinking the 57s in the front but now im thinking the rear..
. They flex awsome on the rear though
fourwheelerjeff said:i thought most people were getting away from the 57's on the rear because they bend too easily. i bought a blazer with 57's on the rear all bent up and the guy said the springs lasted 6 hours wheeling before they were no longer usable.
are you runnning 3 inch wide 57s??SCOOBYDANNN said:Im running 56's front and 57's rear-good shocks and anti-wrap bar do wonders--
bump got another set today so how about 57s front and rear![]()
i see what your saying but you can make up with it in the valveing of the shocks..if your gonna do something like this you have to buy some bling-bling shocks to go with it...I've been following these threads sorta casually, and I'm starting to wonder how much suspension flex do you actually need? Have you considered that by going to the most flexible, soft leaf set, you might be trading off real world on-trail stability? With 600+ lbs of unsprung weight (and given how fast an axle can move when a truck starts to bounce, I wouldn't necessarily buy the argument that unsprung weight doesn't matter at low trail speeds...) at each end and soft springs, a lot is going to depend on shocks and a rear traction bar, and the front end is still going to hop on climbs unless you tie it down with the winch. Add big tires at low air pressure (which basically are an un-dampened air bag spring) to the mix, and it might become difficult to get the power to the ground. It's your truck, but I'm just wondering...
I agree. Just make up your mind & do your swap already please.![]()
!!Oh, you're such a biitch sometimes![]()
I think it's my increased post count...holy crap you're already at 8K![]()
