6.2 diesel exhaust
trailblazr81
Hollister, CA
Im looking at getting a diesel blazer. Miss my old gas one but Im thinking of going oil burner. What do you people run on a N/A diesel Blazer? Would a 2 chamber work/sound ok on a diesel? I would think that something straight through would be best, but whats good and cheap? Jegs and Summit have knock off 2 chamber mufflers for $30 and glasspacks are always cheap. Just dont want to sound like @ss. Also what size pipes? Havent found cheap headers for a diesel so I guess I would just go with stock manifolds.
2.25" for duals, 3" for a single. Glass packs fill with soot and are not recommended.
Can you run a straight pipe in CA? I'm fairly certain you aren't supposed to.
Theres alot of things yer not supposed to do in Cali. but that nerver stopped me. (shh) I would think straight pipe would be a little too loud. The neighbors wouldnt appreciate it at 6 AM.
Why would you want to change it? I can't even remember what they sound like, but they are all duals AFAIK already, and very stout at that.
Well just wanting to help the flow, decrease backpressure. My 98 K2500 with 6.5 TD now has a 4" exhaust with straight through muffler. I know the 6.2 N/A wont need that much, but just helping it breathe easier.
6.2 is so anemic to start with, wondering if any of our diesel guys have any comments on that? I'd be real surprised if an exhaust made a real difference on a stock 6.2. Although at the time, 3"+ pipe certainly wasn't common for automotive exhaust...
Well, C-code 6.2's are anemic because they only make 130HP and the vehicles they come in have 3.42 or taller gears. Stick bigger tires on and things get even worse.
A decent exhaust will help other mods work to their full potential. I would stick with a single 3" or 3.5" exhaust, preferably run down the passenger side. It will flow as well as a pair of 2.5"s, you only have to buy one muffler, and it will be in place and ready if you decide to turbo it :D
GM produced NA J-code 6.2's with power ratings of up to 165HP (I know because I have one :wink1:). The main differences between it and a C-code are the intake manifold (all J-code intakes are not the same, BTW - there is a divided and an undivided version, and the 165HP 6.2's and al 6.5's have undivided intakes AFAIK), the prechambers (3-dot @ cups in the 165HP 6.2 - NA 6.5 cups should be comparable), and the pump calibration. Turn up the pump a bit (and have an EGT gauge that you watch like a hawk) and you can probably get that combo up to around 175HP with acceptable levels of smoke.
I am running dual Glass Packs and it sounds really great on a 6.2 It is a little louder after they break in but I like it and noone sweats it here. No louder than the flowmasters on the Galaxie 500. I love the way that 6.2 engine sounds.
i used to have glass packs on a 6.2, and it did sound good. but glass packs will fill with soot as mentioned before
The 6.2, in regards to sound, responds the same as a gas motor. I've had dual exhaust (factory style) with 2.25" glass packs and some sort of "turbo" muffler, and now a pair of 2.5" 40-series Flowmasters. They all sounded good and always got comments from other people, most stating that it didn't even sound like a diesel until you got close enough to hear the motor clacking.
I will say the 40-series Flows were substantially louder inside the cab versus the previous turbo mufflers, but this was also a trailrig with a stripped down interior and no pipes after the mufflers. I did finally put about an 18" tailpipe and turndown after the mufflers and it helped a bunch.
