6.2 Diesel Parts Wanted
nitro_rat
Lufkin, Texas
I have an '84 K10 Suburban with the 6.2 Diesel and am looking for some replacement parts. Please let me know if you have the following:
1. Firewall insulator panels for the evaporator box (passenger side) DEAL PENDING
2. Fan shroud (just the main part that goes around the fan) DEAL PENDING
3. Air inlet tube from core support to air intake baffle ('82-'83 only part I think) DEAL PENDING
4. 454 Electric pusher fan and associated brackets (mounts on driver's side in front of condenser)
5. Factory Aux. Trans Cooler and brackets (stacked plate style, mounts on pass side in front of condenser) DEAL PENDING
6. 6.2 Diesel Air Cleaner Studs and Nuts (one of mine is stripped. I'd like to have a set) DEAL PENDING
7. Crossbars for Factory Roof Rack (if somebody has some lying around, mine are missing!)
8. 8.5 Gov-Lock (in good working order)
9. 8.5 4.10 Ring & Pinions (a pair for front and rear)
I will update this thread as my needs change. My shipping zip code is 75949. Any help with these items is greatly appreciated!
I have an extra fan shroud in good condition. I will dig it out Tuesday and get some pics.
I dug it out and found it isn't perfect. One big chunk is missing from the fan area. Probably was damaged when the truck was totaled. $25 plus shipping if your interested in it. However, I would expect shipping to run over $50 due to the size.
I have 1,3,5&6
6. 6.2 Diesel Air Cleaner Studs and Nuts (one of mine is stripped. I'd like to have a set.
So the firewall cover you only need the one on the heater box?
Also these are the parts I have for the air inlet, any of them match yours?.
Also shown are the intake/ air cleaner studs.
I have 3 sizes of the stacked plate coolers:
Which do you want?
Yes, just the one on the evap/heater box. PO chopped mine up to replace the blower motor. It needs the heater core and evaporator now, so it's time.
The one on the bottom is the one I'm looking for I think. It's the one that goes from the "silencer" to the core support. Mine never had it. Still has the metal "knock out" on the core support. I think I have the plastic part that snaps into the core support already somewhere.
Just picked up a non-EGR intake with good studs.
Which do you want?
I think the one in the middle if the brackets are for the 81-91 style core support.
Thanks!
