Any tricks to getting these buggers out? I think I'm down to 3-4 functional glow plugs, but I'm scared to snap them off. I just put an open ended wrench on them, but they don't want to budge.
Yup, they seem flimsy compared to how much torque you can put on. Also, being square they seem like they might round off with only an open ended wrench on there. Snapping off flush would really suck.
). FWIW, I've replaced 2 sets, and none of the plugs gave me any trouble, aside from tight quarters on the turbo manifold.They only need to be snugged up to maybe 5-10 ft lbs at most
It's been a while since I made my last attempt. Is it a 12-point deep socket that you use? I know it was a square with the connector on top that would need to be cleared. Thanks.
But, as dieselforme said, using 3/8" on the 10mm is a useful extraction technique.I wouldn't use an open-ended wrench for this job. IIRC, a socket is more convenient, anyway (and a requirement if you have a 6.5TD manifold installed).
There's no reason for the previous owner to have torqued them down tight. So we'll hope he had some sense and was careful with them (&
5 ft-lbs? Wow. If so, that would explain why they just about fell out in my hand. I remember my manual saying 35 ft-lbs. Now I wanna go check.![]()
