I've been thinking about adding an intercooler to my banks turbo'd 6.2
do you think it would be worth it or just a waste?
space and looks are not a consideration
before ic installed. The turbo that the banks kit uses doesn't work well with an intercooler. It doesn't move enough air to be beneficial. So unless you're planning on getting a better turbo I would leave it non-intercooled. If egts are an issue you could always add water-injection.
. A stock 6.2 even with the intercooler I wouldn't push past 15lbs of boost, especially with stock head bolts. I run head studs, a wise investment on any engine.
