The smoke on start up I think is either dead glow plugs in a few cylinders--or perhaps a few cylinders are losing compression..could be the injectors ,they have never been touched..but as long as it runs OK warmed up I'm not going to go looking for more troubles..
Yeah,I knew that could happen (the electric pump filling the crankcase if the lift pump diaphragm fails),but having the electric pump in tandem makes bleeding the system so much easier,and the engine seems to start faster and run peppier with it too..
Also if the lift pump fails,it still can fill the crankcase with fuel too...and its such a sucky location its mounted in,I don't feel I could be successful at replacing it..
Frankly I'd rather yank the engine out and leave it out if it needed a lift pump..its just one more nail in its coffin....it has enough other potential failures waiting to happen I just assume stop throwing money at it..as it stands now it needs at least a few glow plugs,the oil pan replaced,the passenger side exhaust manifold is ready to crumble,and it is noisy enough to make me think it is nearing its end ,period..
In the past when I changed the fuel filter or stupidly ran it out of diesel,all I had to do was open the bleeder on the filter,turn the key on,and the electric pump would fill the lines and filter,and I didn't end up cranking it so long that the batteries died,or the starter burnt up..
I roached 2 starters and the batteries after running it out of fuel twice in the past 10 years..that alone doesn't exactly make me fond of diesels..nothing on this engine is "inexpensive" either..
I've looked locally for another electric fuel pump--all the usual stores like Autozone,Pep-Boys,Advanced Auto,all stock either Mr.Gasket or Holley pumps that look identical,and they SUCK,I've seen at least a half dozen of them friends bought fail either right away,or shortly after installing them--they have to be "gravity fed",they aren't self priming,and they sell for over $50--screw that junk..
Online you can find hundreds of different pumps starting under $10 from Amazon,E-bay,but their reviews are full of "don't buy these--they are junk" posts...
I had one brand new pump identical to the one on my truck I bought for $1 at the flea market,still in the package,I bought it for a "spare",but ended up using it on a garden tractor instead--it worked great all that summer--6 months later I went to use the tractor and the pump started smoking as soon as I turned it on,and then it croaked..
I did an autopsy on it,inside of it looked like roofing tar,the gas turned the rubber bellows into goo..
So I'm not a big fan of the "fuel filter" looking electric pumps or the Mr.Gasket style junk--if I buy one ,it'll be the "cube" design like a Facet brand,with a plunger instead of a bellows diaphragm type..
Funny the one on my truck when I got it lasted 16 years and roughly 10,000 miles though..I think diesel is less destructive to the innards than ethanol gas is..
It is a bit un-nerving to think these pumps could fail and start the fuel on fire--this one didn't even pop the 5 amp fuse,but the ground wire on it melted and came right out of the case when I touched it..
There are integrated circuits,resistors and capacitors inside the pump too,probably submerged in the fuel..
For now I may just by-pass the electric one with a hunk of brake tubing,put it back to stock,and pray the lift pump doesn't croak next..
I'm not feeling great and I'll be lucky to get that done,I'm feeling like a 80 year old cripple lately..--it will be a hassle to get a credit card so I could order anything online,it is bad enough I have to blow at least $40 on glow plugs when I'm dam near broke from paying my property taxes and utility bills..
I also now have to get two more tires that "match" two on the truck,
I had some scary drive line "BANGS" plowing with the mis-matched ones on it now,was lucky I didn't break something ..more $$$ I don't really have to spend on this p-o-s..
