buff_dog70
Going to try and upgrade my 1982 Jimmy with 6.2 diesel to a Serpintine belt system with the High Output water pump (1997+). It has the ability to pump 130 gpm vs stock 87 gpm.
Before I dissassemble my running vehicle, does anyone know if the HO pump bolts up without modification? The HO pump was designed for the 6.5 engine, but I think it will fit. I know when it runs with the serpentine system it turns the pump in the opposite direction than older type water pump.
Also I saw I might need the twin thermostat system, does this bolt up without modification, I was going to the junk yard to go look for one?
I think I have serpentine stuff but was wondering if anyone had any good pics or walkthrough of for this mod.
The HO water pump is well worth you time, and is what I did with my truck as well. I don't think there is any difference between the two backing plates, but the one I had from my 6.5L was less corroded so I used it instead of the 6.2L piece.
