So I have an amazon gift card. I need to buy a gasket kit for my 6.2.
Can only find 6.5 gasket sets on Amazon.
Will they work?
Will they work?
Will they work?
No. Sometime ago I talked to a couple engine builders their 6.2/ 6.5 knowledge is substantially less than mine.
I have read that people use them. Only difference being a cooling port
I'm no expert,but a quick look at listings on RockAuto shows the same part number Fel-Pro head gaskets for a 6.2 & 6.5,and I "think" the cylinder bores are the major differences in the two engines (and the stroke?)..
Same part numbers for turbo & non turbo too..
They do list a head gasket thats .010 thicker for engines that had the block resurfaced..
I'm betting all the other gaskets are the same,but I didn't look every one up either--the 6.2's after '87 and 6.5's had one piece rear mains and a different oil pan "smile" gasket,I know..
I dont know if that is possible--my guess is the rear of the block is different for a one piece rear main,and you'd have to replace the oil pan too,they are different than the two piece seals..
I don't see the two piece seals being all that troublesome,I dont see that many being replaced--but I have seen quite a few one piece rear mains in other engines leaking and have to be replaced..which requires pulling the tranny or engine...a two piece can be done "in the truck",with some patience and one of those "chinese finger" tools..
Headgasket have minor but important differences, there are a few different gaskets/o-rings for the thermostats, and the rear main seal is either 1 or 2 pieces. Other than that, it's all the same between the GM built engines.So I have an amazon gift card. I need to buy a gasket kit for my 6.2.
Will they work?
David
This is the tool you can snake in a rear main seal with (2 piece ) ,by just removing the oil pan and rear main bearing cap...doing one with the engine out is a lot easier..View attachment 197579
I must be lucky,only my rotted oil pan leaks on my pickup,and so far the suburban is dry at the rear main--after sitting several years though,I wont be surprised if it starts leaking,if and when I ever go to drive it..
...but yeah,I wouldn't yank the motor out just to do a rear main...Lying on my back with oil dripping in my eyes isn't as much fun as leaning over an engine on a stand......but yeah,I wouldn't yank the motor out just to do a rear main...
is it worth doing? The oil pump that is?
