I'm swapping the blown 700r4 in my '85 K20 diesel Suburban next week and I think I have everything lined up but I want to bounce it off of you guys to double check. Here is what I have:
2000 Chevy 4x4 nv4500 with bell housing and shifter
NP208 from a cucv th400
Both the 700r4 and a th400 cross members. The 400 is from a cucv
Hydroboost clutch pedals from an '87 3500
Here is what I plan on ordering this week:
6.2l single mass flywheel and bolts
6.2l clutch, not sure on which one yet
The internal slave cylinder for the 2000 transmission
Hydraulic master cylinder for the '87 pedals
The line and fittings for the cylinders
The GM fluid for the trans
The only thing I'm not 100% confident in is which clutch to use and if the master cylinder and slave will marry up so any advice or better yet, personal experience it greatly appreciated.
The Suburban is going to be used for trips out to the desert and trail riding, it has 4.10s in the 14bolt sf and 10 bolt front. I have a set of cucv axles, dana 60 and 14FF to swap into it at a later time.
